Smokin briggs
Old 06-01-08, 06:23 PM
Smokin briggs
Hey I have a briggs 14.5 OHV i/c quiet
Model#287707
type# 1224-e1
code# 9710162e
For what ever reason it started leaking oil onto the muffler. A loss of power starts off a smoke fest. I stop mowing for a second or two and it returns to normal.
Please help.
thanks
Ironhead69
Old 06-01-08, 07:18 PM
cheese's Avatar
Received 17 Votes on 15 Posts
Check the oil. I'll bet it's overfull, thin, and smells like gas. If so, clean the carb and replace the float needle. Then when the carb problem is fixed, drain the oil and refill with fresh clean oil before running the engine.
Old 06-05-08, 04:12 PM
Thanks
Thanks Cheese, will check that out.
Old 06-07-08, 04:08 PM
back mowin
Took off carb, sprayed it out but didn't change out float pin, changed oil and runs like a champ.
Thanks again Cheese!!!
Old 06-08-08, 08:53 PM
cheese's Avatar
No problem! Just make sure you've got the carb problem fixed or it will happen again. It doesn't happen while it's running, it happens when it's sitting there for a week unused.
