troy-bilt tomahawk shredder
busysteve's Avatar
OR
06-02-08, 08:19 PM   #1
Just inherited this thing. Seems to be missing some sort of screen or plate on the bottom below the flailing blades. Any one have a parts list that might indicate my missing (?) parts.
Thanks
smallengineguy's Avatar
MA
06-03-08, 04:38 AM   #2
Post your model number
busysteve's Avatar
OR
06-03-08, 09:57 AM   #3
Thanks for responding. The model number of the troy-bilt tomahawk shredder is:11427 The serial number is: W402633 Hope this gives enough info.
Steve
bontai Joe's Avatar
PA
06-05-08, 10:24 AM   #4
I see these screens on Ebay pretty regular if yours is the box shaped model roughly the size of a 3 drawer file cabinet. Do a search for "Troy wood chipper".
marksr's Avatar
TN
06-05-08, 12:20 PM   #5
IF I remember correctly, the screen/guard is optional. It's purpose is to help grind the mulch up better. Without it you will just have bigger mulch pieces.
retired painter/contractor avid DIYer
bontai Joe's Avatar
PA
06-06-08, 09:09 AM   #6
If your Tomahawk chipper looks like item #260246968717 on Ebay ( I have on connection to this auction, just using it for the pictures) then you need the screen on the bottom for safety's sake. Otherwise large pieces will be flying out the bottom possibly causing injury.
Gpa Dle's Avatar
11-02-08, 05:30 PM   #7
Gpa Dale
My Tomahawk shredder hammermill use a 5L290 belt, That is an L sized belt 29 inches long
Gpa Dle's Avatar
12-04-08, 04:27 PM   #8
Improvements to Troybilt Tomahawk
If you have a Troybilt Tomahawk Shredder, I can tell you of at least 6 improvements I have made to mine
Also how to make your own flails
Gpa Dale
Ron Wittmann's Avatar
11-09-09, 04:45 PM   #9
Troy-bilt Tomahawk 11427, sn W400355
The clutch mechanism disassembled during use and I lost a spacer (part no. W209010023). Can this part be purchased anywhere? Are there suitable substitutes? I'm also due for a new knife and hammers. How can these be obtained? Thanks.
bontai Joe's Avatar
PA
11-11-09, 08:00 AM   #10
Ron, I can't help you on the clutch parts, but if you haven't done this yet, you can turn the hammers and the chipping knife 180 degrees and use the cutting edges on the opposite sides. Plus they can be resharpened.
