Anyone familiar with Sears Roto-Spader
Old 06-07-08, 04:14 PM
Just was given a Sears Roto-spader 4 h.p. Front tine. Doesn't want to start. Gets fire, Gets too much gas. Previous owner tinkered with, used to run but would bog down under load.
Any info info appreciated.
Model # 785 298041.
Also need a drop bar for back if anyone has a spare lying around.
Thanks
Ironhead:mask:
Old 06-07-08, 09:08 PM
Also need info
Model # 785 298041.
Thanks
Ironhead:mask:
Also need info for parts. Need a carb real bad
Old 06-08-08, 08:39 AM
Found a engine ID tag
I also found an ID tag on the engine for this tiller.
Tag ID # is
143.173022
6334
12028
Any info would help.
Thanks
Ironhead
Old 06-08-08, 08:21 PM
cheese's Avatar
Received 17 Votes on 15 Posts
I'm not familiar with it. About all I can tell you is that the engine is a tecumseh (you probably already knew). Check back, someone else here may have some info.
Old 07-29-08, 05:38 PM
Hello; Ironhead. I tried to cross-reference your engine number in a Sears- Tecumseh list but apparently there is a digit missing in
the engine number you posted. Verify the number so I can try again.
Good luck
Natureman
Old 04-08-09, 09:04 PM
tiller
I have a sears rotor spader 6 horse If its getting to much gas I would say that your needle is stuck open the one that the float moves. you can still buy a rebuilding kit for this carb. ABOUT 10.00 there are two o rings I believe on that carb that neele valves seat against, one being the float needle check out this sight How To Rebuild Tecumseh Carburetors
