bs 14.5 rocker arm and push rods
detargett's Avatar
MI
06-12-08, 07:13 PM   #1
i have a 14.5 briggs in a craftsman rider. i just replaced the head gasket and rebuilt the carb i had it running for about 15 minutes then it seemed to be losing power when mower was engaged. took off valve cover and found rocker arms loose
so i adjusted them then ran the engine and after 5 min. it died i pulled the valve cover again to find 1 rocker arm completly off the valve and pushrod i re adjusted several more times to have it do the same thing again and again am i missing something? or what is causing this
model number on engine is 287707 ohv 14.5
thanks
dt
cheese's Avatar
GA
06-12-08, 11:59 PM   #2
Is the torx screw down in the center of the rocker arm? Is that screw tight when you adjust the rocker arm nut?
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
detargett's Avatar
MI
06-14-08, 06:14 AM   #3
thanks
the torx screw had fallen out thanks for your help valves are now set. once again thanks
DT
epauleyjr's Avatar
OK
06-14-08, 12:43 PM   #4
i got the same thing going on whats the setting for the rocker arm .
epauleyjr's Avatar
OK
06-14-08, 12:46 PM   #5
i got that same engine 287707 14.5 hp b&s
cheese's Avatar
GA
06-14-08, 10:27 PM   #6
Glad you got it!
epauleyjr, set both valves at .005"
God bless!
