nothing
Old 06-14-08, 05:51 PM
nothing
i have a craftsman rider LT 4000 model #917.254850 was running fine, then stopped. now nothing . every time i turn the key it blows the fuse. i have changed the selonoid, the ignition switch and wired another plug on for the ignition switch and still keep blowing fuses.......any helpful info would be appreciated...THANKS
Old 06-14-08, 10:01 PM
cheese's Avatar
Do you have an ohmmeter or test light? You have a short. Disconnect one of the battery cables and connect a test light from the cable to the battery. Turn on the ignition, unplug the carburetor fuel solenoid, and look at the test light. If it is glowing, the short is present. Unplug different components until the light goes out. When the light goes out, the short is gone. If it's not a component failure, then you'll have to chase a pinched, burned, or chaffed wire. Have you had the starter off recently? Look behind the starter for a pinched wire between the starter case and the engine.
Trackbacks are On
Pingbacks are On
Refbacks are On
