Peerless Transaxle 930-057
YDuaneS's Avatar
MO
06-18-08, 01:17 PM   #1
Original Equipment on my Craftsman 19HP Model 917.256660.
(a) If required, where is the grease plug located on the transaxle for adding grease?
(b) Used 3 days ago without problem, now when I put in any of the 6 forward and 1 reverse gears it is as if in nuetral regardless of engine on or off. Any suggestions?
cheese's Avatar
GA
06-18-08, 11:03 PM   #2
It's a sealed unit and there's no grease plug.
It sounds to me like the tranny belt came off.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
YDuaneS's Avatar
MO
06-19-08, 08:18 AM   #3
Thank you, cheese.
Is putting the tranny belt back on something a person with modest mechanical skills can do? If so, any reference instructions you can lead me to?
Fisher40037's Avatar
KY
06-19-08, 10:30 AM   #4
Did you have one of the wheels off?
Fish
YDuaneS's Avatar
MO
06-20-08, 09:36 AM   #5
Nope, the wheels haven't off for a long time.
cheese's Avatar
GA
06-21-08, 12:17 AM   #6
Fixing the belt (if that's the problem, did you check?) isn't hard. Look under there and see. If the belt came off, it's probably in need of replacement, and there is likely another problem that contributed to it coming off. There may be a bad idler pulley as well. The belt should be fairly simple to install. Generally the v part of the belt goes in the v groove pullies, while the flat backside of the belt goes against the flat pulley(s). Make sure the belt is not touching the belt guides anywhere when the belt is tightened/engaged.
God bless!
YDuaneS's Avatar
MO
06-23-08, 06:39 AM   #7
Thanks, again. I really appreciate you taking the time to respond!
