rider mower won't move
Old 06-28-08, 02:20 PM
my rider suddenly stopped moving a couple things I noticed is when the rider is off and I have it in gear I can't roll the it the transmission seems to be working. The belt seems to be loose not ever working on it before I'm not sure how loose it should be. Thanks in advance for any help..
-Chuck
Old 06-28-08, 03:05 PM
hopkinsr2's Avatar
If you tell us what make, model of rider you have, It would help a lot. But for now, check the rear wheels. If they are suposed to have a key in the axle, verify it's there & hasn't fallen/worn out. The belt may be loose if you have the brake on (some models). Also verify the input pulley is infact driving the trans input shaft. (maybe a key sheared/missing??) Post make & model numbers & the pro's will help you soon!!! Roger
Old 06-28-08, 09:45 PM
cheese's Avatar
Received 21 Votes on 18 Posts
Not knowing what you have, I'd toss a guess out that your belt has come off a pulley.
Old 06-29-08, 04:57 AM
Model
the rider is a Craftsman Lawn Tractor 21.5 hp 42" Electric Start 6 speed transaxle model # 917.272454
Roger thanks for the help
