2 Stroke Lawn Boy Govenor Spring
Old 06-28-08, 05:15 PM
hopkinsr2's Avatar
Greetings to all,, I have a 2 stroke Lawnboy with a broken govenor spring. the model is 22261 & serial is 220000448.. My question is, how do I remove the air vane/throttle shaft to replace the spring. The throttle plate looks as if it snaps into the throttle shaft, but may cause some damage if I pull it out of the throttle shaft... Any hints or tips are greatly welcome,,,, Thanks lots, Roger
Old 06-28-08, 08:41 PM
cheese's Avatar
With throttle plates that just snap in, I just grab them with a pair of pliers and pul them out. You might have to use a thin flat blade screwdriver to help open the slot in the shaft, but generally the plate will just pull out with gentle persuasion.
Old 06-29-08, 09:10 AM
hopkinsr2's Avatar
Thanks lots, Cheese.. Sometimes I'm just too gentle with stuff..LOL. I did get it pulled out, & a little penetraiting oil seemed to help as well!! Thanks again... Roger
