Need tips to fix Ryobi Wipper snipper
greenhulk's Avatar
WY
06-29-08, 03:47 AM   #1
My Ryobi W/S needs a service. Model RVC31EP. It is one of these units with the ABC choke. It will only run on B with no throttle, when you switch to C or use the throttle (even in the B position) it really struggles and dies.
When I let out more cutting wire or cut some heavier grass it goes to die also.
What should I be looking at to fix this problem.
If its related to the carby, Is there a way or product I can use to clean it withour having to pull it all apart. Im not real familiar with these devices.
Cheers
flirty1's Avatar
MI
06-29-08, 04:03 AM   #2
the only way to clean the carb correctly is to dissasemble it and clean it and install a rebuild kit(about $12) if you don't want to mess with it or pay a shop you can by a whole new carb
jsouth's Avatar
TX
06-29-08, 06:35 AM   #3
Go to the nearest auto parts store and pick up a can of seafoam,and put a ounce in the carb.about $6.00 a can and let it idle in the B position,for about 5 to 10 minutes.I had good luck with it.Hope this helps.
Jerry
