crafstman / briggs and stratton carb help
gibbo's Avatar
MA
06-30-08, 08:58 AM   #1
First time to the site and I need some help. I have a Crafstman rding mower with a briggs and stratton engine that I have just rebuilt. Unfortuanetly when I took the carb off the engine I did not note how all the springs and connections were made. Could some one please help with a pic from thier setup. I figured out the choke linkage but not the throttle. I know you folks will probbaly need more infor but I am at work right now and do not have it. It is a green tractor, 42" cut, with a briggs and stratton engine, ohv, with a hydro tranny. Thanks in advance for the help. Let me know what other info you need and I will get it asap.
Steve
Airman's Avatar
TN
06-30-08, 09:23 AM   #2
Hopefully the link below will help. See step 5 image D.
http://faqs.custhelp.com/cgi-bin/faq...i=&p_topview=1
gibbo's Avatar
MA
06-30-08, 10:28 AM   #3
close
this is what mine looks like but I need to see the part that is about 6-8" to the right, behind the piece of paper. How it is connected to the other end. I also need to see how the linkage that is controlled from the engine base is attached. Thank you though.
Airman's Avatar
TN
06-30-08, 12:02 PM   #4
Post your engine model and type number and I should be able to answer your question.
gibbo's Avatar
MA
06-30-08, 05:31 PM   #5
model: 28U707 Type: 1174-E1
cheese's Avatar
GA
06-30-08, 08:04 PM   #6
It just hooks into the hole at the top of the governor arm on the side of the engine. The small spring connects there too.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
gibbo's Avatar
MA
07-01-08, 05:33 AM   #7
This really doesn't help. What is the governor arm? This is the linkage coming out of the engine base plate? How does this get adjusted? Pictures would really help if anyone could post them up.
cheese's Avatar
GA
07-01-08, 10:43 PM   #8
It the lever/arm that's sticking up with a hole in the top. It's connected to a shaft that comes out of the engine block. Put the linkage up like you see it in the pic in the link and where the end of the linkage is is where the governor arm is. It should be very evident when you see it. Don't adjust it...it should never need adjustment.
God bless!
gibbo's Avatar
MA
07-02-08, 04:20 AM   #9
It does need adjustment because it was dissassembled when I rebuilt the motor. I am going to have to buy a manual, this should give me all the connections and adjustments, no? I was hoping to avoid it.
