Re-Ring aluminum bore Briggs Question
Old 07-04-08, 06:08 PM
hopkinsr2's Avatar
Welcome to Friday all.. I have a quick question. I have an aluminum bore briggs that smokes bad. Mod 190437, type 5506-01, code 9008061. The neighbor brought me the engine & an aftermarket ring set (Stens, I think) & a base gasket. Now,, The briggs oil ring is 1 piece & his oil ring is a 3 piece. Not a big deal, But,, do I hone the aluminum cylinder for the rings as I would do a steel bore,, Or should I just put the rings in. Also, is the 3 piece oil ring O.K. in the aluminum cylinder?? I thank all lots,,, Roger
Old 07-04-08, 06:21 PM
The 3 piece oil ring is fine. If the new rings are chrome then you don't need to hone the cylinder, otherwise I would hone it.
Old 07-04-08, 10:06 PM
cheese's Avatar
I agree. I would use chrome rings in an aluminum cylinder given the choice.
Old 07-05-08, 08:26 AM
hopkinsr2's Avatar
Thanks, Guys. I do believe they may be cast rings. They only have a black color to them, But I wouldn't know if a chrome ring has a shiny finish, or if an indrustrial chrome is black?? Thanks, Roger.
Old 07-05-08, 08:42 PM
cheese's Avatar
Generally the chrome rings will be grey with a chrome edge at the contact surface.
Trackbacks are On
Pingbacks are On
Refbacks are On
