Craftsman 32cc Brushwacker/linetrimmer
Old 07-06-08, 05:03 PM
Can anyone tell me how to remove the clutch assembly? I have to get to the pull cord line rewinder or maybe i am going about it the wrong way. Any help is appreciated. thank you
Old 07-06-08, 05:39 PM
There should be a screw down inside the clutch drum nose--
after you remove the screw--the drum will have to be ( usually ) forced off--take your time--don't damage it............
Old 07-06-08, 07:42 PM
I think the screw jhoward is referring to is a T20 torx and before you destroy something remove the spark plug and fill the cylinder with starter cord or small rope to keep the engine from turning. Have a good one. Geo
Old 07-07-08, 06:26 PM
Thanks for the info but i have removed the clutch drum screw and drum but i don,t want to break anything because the clutch assembly will not come off easily. Any ideas?
Old 07-09-08, 06:48 PM
[QUOTE=handyman234;1393175]Thanks for the info but i have removed the clutch drum screw and drum but i don,t want to break anything because the clutch assembly will not come off easily. Any ideas? I don't see anything alse holding it on. I don't know if it is a press fit.
Trackbacks are On
Pingbacks are On
Refbacks are On
