snapper riding mower 28A707
art41's Avatar
IN
07-09-08, 06:07 AM   #1
Engine cranks but no spark at plug.how too or what to do to fix this?
Jacks911's Avatar
RI
07-09-08, 09:01 AM   #2
if its electronic ignition, take the cover off, and on the bottom of the coil, there is small wire attached to it. take the wire off and check for spark. if you get spark then, you have a bad kill switch somewhere or something, but the coil isnt the problem. if you disconnect that wire and still no spark, chances are your coil is bad. obv. first make sure the plug is good and grounded well against the engine block.
