Sachs-Dolmar recoil rope replacement
Old 07-10-08, 02:05 PM
Question Sachs-Dolmar recoil rope replacement
I have a Sachs Dolmar BC-330 weed whaker. the reoil and fan/fly wheel is on the back of the unit. Do I have to take the fly wheel/fan combinatioon off to get to the recoil pulley to replace the rope? ?
Old 07-10-08, 10:26 PM
cheese's Avatar
Received 22 Votes on 19 Posts
I don't believe you will have to remove all that. I'm not familiar with that model, but generally you just remove the recoil assembly from the back of the engine and that's it.
Old 07-11-08, 11:46 PM
Red face Can barely see it!!
Well I can barely see the recoil started behind the flywheel/fan assembly??
Old 07-13-08, 12:47 AM
cheese's Avatar
Sorry, but as stated, I'm not familiar with that model. So the pull rope assembly is not at the very back end of the engine? If not, then it would seem that you would have to remove the flywheel to access it, from your description. I don't think I've ever seen any trimmer engine made that way unless it's all at the front of the engine.
Old 07-13-08, 09:57 AM
Rare
Yep it is a rare German made Commerical Brush cutter!!
