Ryobi 725r dies when it gets hot.
rabo601's Avatar
MS
07-13-08, 09:28 AM   #1
It starts & runs fine for 2 minutes. Then it begins to sound muffled and it won't respond to throttling. A second later, it dies and won't restart. What could be the cause of this?
Thanks,
rabo
cheese's Avatar
GA
07-13-08, 04:05 PM   #2
Check for spark at the plug when it won't start. If there is spark, loosen the gas cap and see if it re-starts.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
rabo601's Avatar
MS
07-27-08, 10:58 AM   #3
Thanks for the help
I just replaced all the fuel lines. Turns out the old ones had dry-rot. You can't really see that til you remove them, though. I appreciate the feed back.
Rabo
hifonic200's Avatar
07-29-08, 06:14 AM   #4
ryobi 725r
I have a ryobi 725r. I recently replaced the fuel lines, filter and primer bulb. It starts fine and will idle fine but when load is applies it abruptly dies. Any suggestions?>
thanks
cheese's Avatar
GA
07-30-08, 12:16 AM   #5
You probably need to clean the carb.
God bless!
