briggs 6 hp Quantum valve specs
tybjepp's Avatar
MN
07-15-08, 04:57 AM   #1
I have a briggs Quantum and need to know the valve clearance specs are :? and why the top ( intake i think ) valve would have a clearance of 1/4 inch between the valve and the lifter . and its the original valve i think its the same leignth as the other valve . I got the mower in for repair ? wall:
cheese's Avatar
GA
07-16-08, 01:10 AM   #2
Engine model#?
The excessive clearance could be because of a stuck valve, bent push rod, something stuck under the valve face, rocker arm stud backed out, etc...
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
tybjepp's Avatar
MN
07-16-08, 05:23 AM   #3
valve clearance
valve seat is in place ,valve moves freely and closes fully , is not bent . its not a over head valve motor and the lifters are solid lifters the top lifter may go back firther into motor . but the valve still opens a little with the 1/4 large gap. the motor had low to no compression . thats why i asked the specs of it , well it going to meet a air gun soon and i will inspect the cam inside after i look up the specks. i thought that it was something new for compression releaf . its got to be something with the timing gear and cam lobs.
