MuCulloch MAC 160S Removing Chain
Old 07-15-08, 03:54 PM
standonit's Avatar
I have a McCulloch MAC 160S chain saw that I need to remove to replace the chain.
There seems to be nuts, screws and bolts on the side away from the chain, but there doesn't seem a way to access removal of the chain........I could use some assistance.
Thank you
Old 07-16-08, 12:42 AM
cheese's Avatar
Received 32 Votes on 27 Posts
There should be 2 nuts holding the cover on the side with the chain. Take them off and the cover off and the bar and chain will be loose.
Old 07-16-08, 12:49 AM
R
Looking at the parts illustration here:
http://www.mccullochservice.de/image...ten/100ser.pdf
To get the chain off, you'll need to remove the cover (item 3, chain brake assembly) from the right-hand side of the saw. Then slide the bar all the way back. The chain should be loose enough to come off the bar and around the clutch.
Old 07-21-08, 04:01 AM
standonit's Avatar
Smile Thank You
Thank You Cheese & Rogerflies......I believe a piece of wood jammed the blade. The advice should help me free the chain
Again thanks
Old 07-21-08, 07:15 AM
CAMINO KID's Avatar
Make sure the brake is not applied as you will not get the cover off easily and if you do manage to get it off it will not go back on until you release the brake. The brake is released by pulling the handle towards the unit.
