B&S Carburator Repair
Old 07-17-08, 11:44 AM
Thumbs up B&S Carburator Repair
I have a riding mower w/18 hp B&S engine. The throttle assembly came apart inside the carb. As a result some of the parts where eaten by the engine. Which seems to have survived. There is a part(#690572 spring-detent) shown on the diagram for this carb. Where does it go and what is it's purpose?
Old 07-17-08, 02:49 PM
List the model, type and code number from the engine. This hopefully help pin point the model number of your mower.
Old 07-17-08, 03:00 PM
Engine Info
Model Number: 31H777
Type: 0210 E1
Code: 020525
Old 07-18-08, 04:24 AM
If you will look closely, where the choke shaft goes in on top of the carburetor you will see a small hole (not deep) next to the choke shaft plate. This is where the detent spring is installed, tight fit. The purpose is to provide friction to maintain choke position.
