Electric edger troubleshooting question
Old 07-17-08, 05:11 PM
E
I'm trying to troubleshoot a dead electric edger. When I opened it up, I found that the incoming 120VAC power, which comes down the edger's shaft from a plug up at the top of the handle, is connected to a rectifier. The rectifier sends 120VDC to the motor. When I depress the power switch, there is 120VDC at the motor terminals, but the motor doesn't turn, and the motor shaft can be easily turned by hand, so I assumed the motor is dead. However, there is another set of wires coming off of the DC side of the rectifier. These two wires, one of which passes through a 20W 10 ohm resistor (or maybe it's 10W 20 ohm -- I forget), run back up the shaft of the edger. The handle at the top of the edger has nothing but the momentary contact switch to send power down to the motor, and I have no idea as to what these other wires are for or if they may have something to do with why the edger won't run. Is it some sort of braking mechanism?
Old 07-18-08, 06:03 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: eclipse
Those additional wires ("another set of wires coming off of the DC side of the rectifier".) that return from the rectifier are the unused electrical power return wires.
Chances are the motor is dead or the rectifiers circuit is dead. Best advice, if you're not skilled with electrical circuits or electrical components is to replace the entire edger/trimmer.
Usually not worth the time or $$$ replacing parts in an attempt to to fix it IMO. Opinions and circumstances vary. Use your best judgment and proceed from there.
Check back on your question several times over the next few days for additional replies.
If you need further assistance, use the reply button. Using the reply button moves the topic back up to the top of the daily topic list automatically & keeps all communications in this one thread.
Regards & Good Luck. Sharp Advice.
30 year Vocational Small Engine Tech. Web Site Admin, Host, Forums Monitor and Multiple Topics Moderator.
Old 07-18-08, 06:16 AM
E
How could I get full voltage at the motor terminals if the rectifier circuit is dead?
