Lawnmower dies!!!!
Old 07-19-08, 08:36 AM
A
Lawnmower dies!!!!
I have a Craftsman riding lawnmower with a B/S engine. It will run until I engage the blades or let off the brake/clutch or push the throttle up to the bunny then it will die. I replaced the filter which smelled a little of gas and replaced the spark plug with no positive results. Any ideas would be greatly appreciated!!!!!!!!
Old 07-19-08, 01:28 PM
G
I have a B&S engine on an MTD riderr that does the same thing. Mine stops running under load. I ordered a magneto armature ( coil) for it since a lot of places suggest the problem is likely that if it's not these. Here's the order from simple fix to more advanced according to a tech:
1. Air filter/ Plug faulty ( not likley but clean it anyway or replace it)
2. Vapor lock ( replace the gas cap or loosen the cap to see if it still runs)
3.Carb- mine was replaced prior and did not fix the problem.
4. Magneto armature ( coil that fires the spark plug) **** hopeful that should solve it. Considering a local place stocks 53 or them, it might tell you something.
5. Engine or Valve prob- ( i'm trying the coil before I get that far into it)
BTW- Only purchase B&S part since many around the net report DOA or short lived part life with Generic replacements.
Old 07-19-08, 01:54 PM
A
Does it die when you release the brake clutch even if it's not in gear?? If it does, this could be a safety interlock problem. The fact that you said it will die when placing the throttle control in a high speed position, indicates a fuel delivery problem (carburetor).
