string breaks on elec. weed eater
Old 07-19-08, 11:26 AM
Unhappy string breaks on elec. weed eater
When I start my electric weed eater, the string breaks off right where it exits the little hole at the spool. It looks like it's been burned, and is jagged. The hole is jagged and I wonder if filing the hole to smooth it will help. Has anyone else had this problem. It was working fine. Thank for any help. EL in NC
Old 07-19-08, 01:26 PM
30yearTech's Avatar
Most trimmer heads have some sort of metal line saver where the string exits the cutter head. The line saver may have come out of your trimmer head and if so the line will continue to break.
If you have your owners manual, you may want to check and see if there is a parts break down that you can compare to your trimmer head to see if all the parts appear to be in place.
Old 07-19-08, 03:48 PM
Wink weed eater string breaks immediately
I never thought about that. Thanks! I filed the opening and made it smoother, and it worked for quite a while. And then the string starting breaking off again. I am going to look for that book that I'm sure came with it. Thanks. EL in NC
