Push mower dies when blades touch grass.
Hey all,
I have a troy-bilt self-propelled push mower. It was working fine until I hit a decent size rock (~5 inches). After that, it will start up fine, but once the blades touch the grass...it acts like I am trying to mow 8 inch grass blades that are soaked with water.
The mower keeps wanting to die.
So my question I hope is obvious..."Does anyone have an answer to help me fix my mower?"
Thank you!
Stats below:
Model #:
TUFFCUT 210
12A-566N063
21" Cut / 6.75 HP
Briggs/Stratton
Thank you!
Stats below:
Model #:
TUFFCUT 210
12A-566N063
21" Cut / 6.75 HP
Briggs/Stratton
Blade is most likely bent and one side is lower digging into grass.
Remove spark plug and tie safety handle allowing you to spin blade freely. Take a visual mark inside deck housing and spin blade. I will bet one side is much lower. Even though mower is starting fine I would check flywheel key, may be partially sheared. Lastly while spinning blade look at crankshaft to see if it is bent.
Good luck
Good luck
