John Deere LT155 w/ Kohler CV15S-41562 No Spark
Old 07-25-08, 07:41 PM
D
My tractor was running fine last week and then when I went to start it the engine would crank but not start. I used a spark tester and witnessed no spark. What next?
Thanks
Old 07-25-08, 11:18 PM
cheese's Avatar
Received 97 Votes on 90 Posts
What did it do, shut off and then not start back up?
Unplug the kill wire from the coil and check for spark again. If still no spark, your coil is bad.
Old 07-26-08, 06:52 AM
D
It was a week later and I sat down to start it and then no spark. Which wire is the kill wire?
Old 07-26-08, 09:48 PM
cheese's Avatar
If your engine does not have a S.A.M. module (black box with 7 wires coming from it mounted on the black engine shroud), the kill wire will be a single white wire going under the engine shroud. Don't confuse it with the pair of wires that go to the 3-pronged connector on the regulator/rectifier.
Old 07-27-08, 05:27 AM
D
OK. Thanks. I will try that.
