Homelite trimmer clutch removal
Just Joe's Avatar
08-02-08, 07:40 AM   #1
I need to replace the pull cord on my older Homelite trimmer but the red plastic housing is all one piece and needs to slide off over the clutch. The clutch is mounted on the crankshaft and no obvious way to remove it without bending the thing. Any help here?
Just Joe's Avatar
08-02-08, 08:37 AM   #2
Homelite Trimmer Clutch Removal
Ha! After I posted the thread, I went out and looked at it again; no way it presses on/off, and no pins, so I tried to unscrew the clutch plates using a wide channel lock pliers while retainint the flywheel and it unscrewed just as nice as you please! The threads are against the direction of rotation so it will never unscrew while running. Self-solved!
cheese's Avatar
GA
08-03-08, 12:14 AM   #3
Glad you figured it out !
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
