Briggs & Stratton 8HP Magneto disassembly
paul_ttn's Avatar
08-05-08, 02:14 AM   #1
Hi, an old engine which I'm trying to put new life into but I'm having trouble fathoming out how to remove the Magneto Flywheel. I've removed the top screen which gave access to a nut on the end of the Crankshaft which I also removed. There now appears nothing to stop the Flywheel being removed but it wont budge. On the flywheel it states do not pry etc., In the center under the nut I removed I can see what looks like 2 thick washers with cut-outs in, although rusted up there appears to be no obvious screws etc., holding the flywheel down. The Model is a 191707 Type 1153
Appreciate any help.......
GlenM's Avatar
OK
08-05-08, 02:59 AM   #2
You will need a flywheel puller, the Briggs site will give you a parts breakdown on your model, oftentimes it will show what puller is needed, they're cheap.
paul_ttn's Avatar
08-06-08, 12:43 AM   #3
Flywheek Puller
thanks Glen, I've a copy of the Parts Breakdown from B&S but it doesn't quote a puller. Had a look on the web and they appear plentyfull in the States (I'm in the UK). They appear to quote 8HP L-Head, I assume mines an L-Head, any chance you can confirm?
cheese's Avatar
GA
08-06-08, 12:49 AM   #4
L-head or OHV, doesn't matter...the same flywheel puller is used. You can also use a steering wheel puller with 5/16" bolts if you have access to one.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
paul_ttn's Avatar
08-06-08, 11:37 PM   #5
Result
Thanks chaps, made something up to put strain on the flywheel over the camshaft, couple of taps on the magnet side and it couldn't wait to come off - yours chuffed!
cheese's Avatar
GA
08-06-08, 11:41 PM   #6
Great! Glad you got it!
This should get me to the minimum 25 characters required to post so I don't get the error message again.
God bless!
