Husqvarna 20HP Kohler Rider No Start Issue
Old 08-11-08, 10:57 AM
A
I have a late 90's model Husqvarna riding mower with a 20 HP Kohler motor. Twice witin the last 2 weeks when trying to start the mower with good charge, the sarter and solonoid just make a dull click noise, i crossed the solenoid with a screw driver and still nothing, just the heavy click noise in the solenoid and the starter will not engage. When this occurred the fist time I inadvertently moved the red starter cable and the mower started, i double checked this connection and the connection was nice and tight. Any help would be much appreciated, the local Husqvarna repair shop is booked two weeks out.
Old 08-11-08, 05:38 PM
R
It doesn't take much corrosion to keep the connection from passing the current needed for starting the engine. Having it start when you moved the wire is a sure sign the connections are causing problems.
It would probably be a good idea to take each connection apart, clean the terminals and contact surfaces with a stiff wire brush, and tighten them back up. You can get special grease to put on the connections to keep them from getting corroded, too.
Old 08-11-08, 10:29 PM
cheese's Avatar
Received 97 Votes on 90 Posts
I'd be inclined to think the solenoid itself is bad if the cable connection is clean and tight. Moving the wire may have been just enough movement at the solenoid to jar it loose so that it could crank again, or sometimes solenoids work once and not again for 20 tries or so, only to suddenly work again (no rhyme or reason).
