B&S Intek Edge Governor
Old 08-12-08, 04:05 PM
I have a B & S 6.5 HP Intek Edge on a Scott Lawnmower. Motor Model # 121602-D121-E1 (about 10 years old)
I was having problems with the mower dieing and no power. Turned out that problem was due to a fouled plug and dirty air cleaner. But while trouble shooting it I took the carb off to check the float. And when I put it back together the motor races at a very fast rpm. (no more dieing and way too much power now) I had bent the LINK-MECH GOVERNOR and tried bending it multiple ways to fix the racing.
I ordered new carb gaskets and a new link-mech wire/rod, thinking that a new one would just drop in. Well it didn't just drop in and I don't want to bend it.
My question is it normal to bend it somewhat when replacing it, and if so where? I.E. is there a procedure for replacing it and adjusting it?
I have played with the governor arm, and if I adjust it so that the link-mech drops in without bending it hits the motor cover. Thus letting the motor run at excessive rpm. Spring is in good shape.
Thanks
Steve
Old 08-12-08, 11:37 PM
cheese's Avatar
Received 97 Votes on 90 Posts
You don't bend the wire. You remove the carb, connect the link, then reinstall the carb. Then you're going to have to reset the governor properly.
