What's the idle speed of small 4-cycle engines?
Old 08-20-08, 05:03 PM
I got an inquiry about building an engine-driven winch using a 4-cycle engine such as a 5HP Honda GC160 or 5.5 HP Briggs Power Built.
What RPM will these engines idle at reliably? Will the idle speed be much lower with a steel pulley about 5" in diameter weighing about 2 pounds installed?
Old 08-20-08, 05:12 PM
Pendragon's Avatar
Received 2 Votes on 2 Posts
Idle speed is probably in the 1500 rpm area, with max rpm around 3000-3500.
Idle speed won't change with the pulley, but it might be harder to start unless it has electric start.
Old 08-21-08, 01:36 PM
bontai Joe's Avatar
That small a pulley shouldn't affect the motor much at all unless there is a load on that pulley. You will NEVER start that motor if there is 1000 pound load on the winch directly tied to that pulley, unless it's disconnected through a clutch of some kind.
