Troy-Bilt Trimmer/TB25CS "Replacing Gas Lines"
Location: Little "o" next to the Big "O" Oviedo next to Orlando Florida
Had Fuel Lines Disintagrate....1 broke in half and the other Line from the Gas tank sheared off @ the bottom of the Gas tank. My Question is after replacing the Fuel line assembly and the return gas-line will this be Ok or should I replace all the other gaslines too?.................TIA
I would recommend replacing them all at the same time as I usually find that all the lines usually deteriorate at the same rate. I would imagine the other lines are pretty close to the same shape as the ones you replaced.
