stops after about 15 min
Old 08-27-08, 04:02 PM
HI, I have a Sears mower with a Kohler CV15S-41567 engine. The mower starts and runs for about 15 min then it just cuts off. I have found that there is not spark after this. Someone told me to change the ignition switch but that did not help. I am not a small engine expert but I am thinking it is something breaking down when it gets hot. Is there a coil or magneta or something like that, that could be going bad when hot? If so where do I get one of those?
Old 08-27-08, 04:08 PM
30yearTech's Avatar
It's probably the ignition module and not the switch thats causing your problem. Kohler part # 12 584 04-S should be the one for your engine. Check with your local Kohler dealer, or you can also obtain from Sears.
Old 08-28-08, 07:53 PM
Thanks, will check that out.
