B&S Engine Loose crankshaft
I picked up a 2 yr old Poulan Lawn Mower off of ebay this week. It has a B&S 123K02 6.5 HP engine on it. The previous owner said it just stoppped running. I figured it was a kill wire or the crankshaft key. This thing looks brand new. I took the mower home and checked the oil. It was bone dry. To make a long story short, the crankshaft is wobbling (loose). I can rock it from where the flywheel mounts. Before I tear into this where would be a good place to look to first. Obviously there are bearing problems somewhere and perhaps other downstream damage. Is it worth fixing ? I think I can do the work. I just need some places to check.
If you can move the shaft in the engine, then there is likely damage to the top and bottom bearing surfaces in the engine block and oil sump. It's likely not a cost effective repair, but if you want to take a look, I would remove the crankshaft and inspect the upper, lower and crankpin journals on the crankshaft and the machined bearings in the block and sump.
Let us know what you find, and if you have any further questions, just ask.
Good Luck....
Good Luck....
Received 0 Votes
Worst case is that they never put oil in it before the first use. That would explain the extreme wear on what appears to be a new engine/mower.
I looked at the listing on ebay. Maybe the power washing made it look so good. At $15.50, it looks like a fairly cheap lesson, though.
Received 0 Votes
Yeah, I know what you mean. I picked up a new mower with a bent crank at the dump in 1968. I cut the crank off at the bottom of the bottom bearing, and sealed up the hole, added a pulley from the water pump of a '56 chevy, a 1/3HP motor from a discarded washing machine, and a pressure switch from a discarded pump. I made a new cylinder head with a check valve (freebie from a salesman), and played around with the valves and springs.
I ended up with a pretty indecent air compressor which I've been using since:
I saved the original oil that was in the engine, and put it back in. It's still there. It's only forty years old.
I did put on a new hose ($2 at a yard sale) a couple years back.
That is a great air compressor !!! I really enjoyed the story - thanks. I guess there are still a few of us left
Previous Thread
Next Thread
