Ryobi 790R "EZ" Trimmer won't stay running
Old 09-07-08, 05:57 PM
Unhappy Ryobi 790R "EZ" Trimmer won't stay running
I could really use your knowledgeable assistance with a problem I am having with my Ryobi trimmer. I all started about 2 months ago when the primer bulb cracked on my Ryobi 790r trimmer with 31cc motor w/Zama carb. I ordered the correct replacement primer bulb assembly from Ryobi and also took the opportunity to replace the foam carb. filter.
After replacing these things the unit started and ran, but will not run on anything past the middle choke setting (1/2 choke). When I remove the choke completely or any more than 1/2 the motor stalls. I have checked the air filter (even tried running without the element in place), cleaned the muffler/arrestor, and checked the fuel lines. I is almost like it is not getting enough fuel since it stalls when the air port is opened more than 1/2 way. The two carb adjusting screws appear to still be in their factory set "middle" setting based on the two plastic screw caps that are on the adjustment screws. The screw closest to the head is yellow and the one closet to the air filter is red.
Any ideas what I need to do???? Thanks, J
Old 09-07-08, 08:05 PM
30yearTech's Avatar
Try opening the adjustment screw with the red cap as far as you can and see if that helps any. From your description, it sounds like your not getting enough fuel and opening up the adjustment may take care of it. There is also a possibility that the carburetor may need new diaphragms or a rebuild kit.
Old 03-30-09, 09:05 AM
i have a 790r 31cc trimmer engine and it wont stay running unless im priming it i replaced the fuel lines and spark already what do i do?
Old 03-30-09, 09:18 PM
cheese's Avatar
Received 22 Votes on 19 Posts
Sounds like the carb needs to be taken apart and cleaned.
