Kohler K321A carb kit
Old 09-09-08, 05:32 AM
I have a mid 70's Kohler K321A, spec# 60294D, ser#7312473 in the shop. It needs a carb kit. I have the parts microfishe. The kit that it shows is $120 and includes linkages. I only need a minor carb kit: needle & seat, bowl gasket, bowl plug gasket and possibly the adjusting needle screws. Parts list says needle & seat ONLY available in the $120 kit. Anyone have a Kohler part # for the minor kit? I never use aftermarket carb kits after having problems with them before.
Old 09-09-08, 06:01 AM
30yearTech's Avatar
I don't know whats different about the carburetor on your engine, but I could not find a listing for a rebuild kit, only a replacement carburetor.
If you can locate the numbers off of the carburetor you may have some luck finding a kit from the manufacturer. Many of the older Kohler engines used Walbro carburetors.
Old 09-09-08, 02:28 PM
UPdate!! With a little bit more thinking, I went back to the Case site that was posted here. (This carb is on that same Case 444). I found the Case part number for the carb kit there.
Case # C27278. I called my supplier, they did have 1 in stock, and she also gave me the Kohler part# of 25-757-01-S. Will be ordering tomorrow from my Kohler supplier as I have other items to get from them. Kohler is a couple $$ more than the Case, but the shipping is the deal breaker. I can absorb the shipping easier on a $75 order than I can on a $10 order.
Thanks!!
