2000 Murray 10HP 30" rider, drive belt problems
Old 09-10-08, 01:34 PM
My drive belt busted and I'm having a hard time figuring out how to get the new one on. Do not have manual, as I bought unit from friend couple years ago. The blade belt is easy, this one looks really hard.
Can you provide instructions on how to replace that belt? Thanks.
Old 09-10-08, 02:25 PM
Get the model number off your tractor and look at this website:
http://www.murray.com/products/combi...=Model&type=OM
If it is not available at the website above google your model number + owners manual.
Old 09-10-08, 11:39 PM
cheese's Avatar
The 10/30 murray tranny belts are pretty aggravating to change. There is a belt guard that is bolted on in the way, and one of the bolts has a nut on the other side....under the engine... There may be some variations, so use your model# to see for sure, but you might want to let a shop do it if you're not mechanically apt or short tempered .
Old 09-11-08, 07:13 PM
Thanks guys. I tried the link and entered model number. Result: nothing. Murray says they don't support anything older than 2003 on that site.
Yes, there is a bolt or nut under the engine that needs to be undone to remove that belt guide. I got that far and then realized the job was bigger than I want to tackle. I have a good mechanic who works on these things nearby. I'll take it there. Thanks again.
Mike
