Honda HDR 214 runs 5 minutes shuts down
Old 09-13-08, 10:31 AM
Honda runs for 5 minutes
Hah- I have you all beat! My Honda HDR 214 (it is about 3-4 yrs old, and hasnt been used in a long while) self-propelled motor runs for 5 minutes before it shuts down. I have to wait an hour for it to cool off before it starts up again. I thought it might be a vapor lock on my mower, so I loosed the cap, but no luck. I am about to attempt to clean the carburetor, but it seems that if it was fouled, I wouldnt get 5 good minutes out of it. Any suggestions?? Thanks
By the way, this is my first post...love the website!!
Old 09-13-08, 11:56 AM
I moved your post so you will have a thread dedicated to your problem. Airman
When the engine quits running and if you have a spark tester, attach the tester and check to see if you get spark immediately after engine shuts off.
If you do not have a spark tester check for spark by removing the spark plug immediately after engine shuts off. Ground the "hex" part of the spark plug to a bare metal part of the engine. Start the engine and see if you have spark.
If you do not have spark the ignition coil is bad.
