Excell 2300 wont run
Old 09-19-08, 08:13 AM
H
I have a small pressure washer an Excell 2300 mdl #EXVRB2321. Unit is approx 4yrs old not much use. Unit starts fine and runs as it should, then in approx 3 minutes its shuts down and wont start. If I wait ten minutes is will start and run ok, but then shuts down all over again. Any suggestions?
Old 09-19-08, 09:11 AM
G
Could be a bad fuel cap, the next time it starts to act up loosen or remove the fuel cap to see if that is the problem. Have a good one. Geo
Old 09-19-08, 02:49 PM
crazycory22's Avatar
also when it shuts down, carefully take the spark plug out, because it will be hot, and check for spark. If no spark, the coil is bad. They usually act up when they start to get hot.
