Help!!!Kracher K2400HH Coupling Element Broken
Vennz's Avatar
09-20-08, 02:55 AM   #1
Hi all,
I have a Kracher K2400 which the coupling element front part which had a bolt nut was broken...
I have grinded the coupling element front to remove the broken bolt, and bought an replacement coupling element online.
Problem now is no matter how hard I tried to hit the coupling element. It just won't get out.
Looking on the online blow up parts, seems like there is a "Spring" inside the Coupling element.
How do I get the Coupling Element out???Do I have to use any special tools?
Vennz
cheese's Avatar
GA
09-20-08, 08:42 PM   #2
I don't have any clue what a "coupling element" is. Here is an IPL for your unit. Take a look, and if you still can't figure it out, note the number of each part in question and reply back.
http://www.pressureparts.com/TreeVie...or=72319#72319
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
Vennz's Avatar
09-20-08, 08:50 PM   #3
Posted By: cheese I don't have any clue what a "coupling element" is. Here is an IPL for your unit. Take a look, and if you still can't figure it out, note the number of each part in question and reply back.
Hi Cheese,
the Part # 91945460 is a spring,under actuation position 4, Part # 5471088 is the Coupling Element. My existing Position 8 (A) Cheese Head Screw have broken and manage to remove the broken pc. inside Coupling Element.
Vennz
cheese's Avatar
GA
09-22-08, 09:13 PM   #4
Ok, I see now. With the #8 bolt out, the coupling should slide off the crankshaft. Unfortunately, water gets all over pressure washers, and it rusts the coupling to the crankshaft. I have had some that were extremely hard to get off. You might grind through the side of it until you get to the crankshaft (don't grind the crankshaft itself!!!). Then spray PBlaster or other penetrating oil in the area and work it until it comes off. Grind through the other side to split it in 2 pieces if you have to.
God bless!
Vennz's Avatar
09-23-08, 05:07 AM   #5
Posted By: cheese Ok, I see now. With the #8 bolt out, the coupling should slide off the crankshaft. Unfortunately, water gets all over pressure washers, and it rusts the coupling to the crankshaft. I have had some that were extremely hard to get off. You might grind through the side of it until you get to the crankshaft (don't grind the crankshaft itself!!!). Then spray PBlaster or other penetrating oil in the area and work it until it comes off. Grind through the other side to split it in 2 pieces if you have to.
Hi Cheese,
Thank you for your reply.. I try it out.
Cheers...
