Homelite Hp180 Blower Don't Blow
Old 09-23-08, 05:10 AM
Angry Homelite Hp180 Blower Don't Blow
This Thing Has Set Up A While, So I Built The Carb, Replaced Fuel Lines And Filter, And Plug... Getting Fire And Appears To Be Getting Fuel.. Will Not Even Attempt To Start.....please, Anyone....
Old 09-23-08, 04:14 PM
30yearTech's Avatar
How old is the fuel you are using?? Have you tried starting with a prime??
Old 09-27-08, 05:34 AM
Homelite Hp180
Yes Sir, New Fuel And Primed...still Nothin' !!!!
Old 09-28-08, 06:03 PM
30yearTech's Avatar
I would remove the muffler and have a look at the exhaust ports, and take a look at the piston and cylinder and see what it looks like. There is a spark arrestor screen that you might want to check and see if its clear as well.
Old 09-29-08, 03:33 PM
Homelite Hp180
It's Not That Old... Acts Like No Compression. What Should Compression Be, And, Would That Cause A No-start??
Old 09-29-08, 07:40 PM
30yearTech's Avatar
I would look for 90 + lbs of compression, if any lower then this is probably your problem. You can try putting a little 2 cycle oil in the cylinder and then try starting, if it fires off and runs till the oil is burned out, then compression is an issue. Could be that the pistion ring is stuck.
