4 cycle oil (what kind to use)
Old 09-23-08, 02:49 PM
N
What kind of oil should I use for my 4hp B&S engine? I think I'm using 10W 30 right now, and it seems to be working fine, but is there something better? Thanks. And while I'm here, can someone give me a basic maintenance rundown?
-Nathan
Old 09-23-08, 02:53 PM
mattison's Avatar
Small engine pro's will clarify but I use straight 30. 10W-30 has detergent in it and you don't want that in there.
Old 09-23-08, 03:41 PM
N
That may be what I'm using at this point, I'm only sure that there is 30 in the name. Do you prefer synthetic or genuine?
-Nathan
Old 09-23-08, 04:43 PM
30yearTech's Avatar
10W30 is fine, or a 30WT HD is also recommended. Both types of oil are detergent oils. Air cooled engines are designed to use a little oil about 2 - 3 ounces per hour of loaded run time. Consumption could be a little higer with a 10W30 oil, so you may have to add a little more often then with straight 30WT.
I recommend checking the oil every time you fill the fuel tank, you won't need to add each time, but if you make it a habit, then you will never run low. Oil is the life blood of your engine.
