Won't Stay running
WildWillMorris's Avatar
09-25-08, 06:58 AM   #1
Won't Stay running
I have a 11hp Briggs on a OLD snapper rider. When you get it started it will run fine until you start mowing, you can get about 15 feet before it dies and it wont start back for about 30 min. i have cleaned the carb several times and changed the inline fuel filter. any suggestions on what is wrong with it.
30yearTech's Avatar
TX
09-25-08, 08:28 AM   #2
Model type and code numbers from the engine please.
Check and make sure the vent is open on the fuel tank cap, on Snapper rear engine riders the vent is manually operated. May also need to open the high speed adjustment a little (screw on bottom of carburetor)
09-25-08, 11:40 AM   #3
the model on the engine is 253707 type 0206 01 and code is 86092611. i tried to adjust the carb with what you said and it didn't help and the vent on the tank is open!!!! thanks again for the help
30yearTech's Avatar
TX
09-25-08, 12:05 PM   #4
When you cleaned your carburetor, did you remove the nozzle and low speed pickup?? (this would be the brass screw up inside where the bowl nut screws in, and directly on top is another brass screw that screws down into the nozzle)
09-25-08, 12:22 PM   #5
Yes i did, I took everyting out except the throttle shaft and choke shaft with the flappers due to not having a plug welch, and blew carb cleaner out every hole there was and tried to adjust it while it was running and it made no change. i also tried to pull the govenor open when it bogs down and had no luck on keeping it running.
30yearTech's Avatar
TX
09-25-08, 12:28 PM   #6
It sounds like a carburetor problem, did you set the float?
09-25-08, 12:30 PM   #7
i don't know, how do i do it?
cheese's Avatar
GA
09-27-08, 01:15 AM   #8
Out of curiosity, when the mower dies, have you checked for spark during those 30 minutes that it won't start? Could be a failing coil if not a carb problem.
"Who is John Galt?" - Ayn Rand (Atlas Shrugged)
God bless!
30yearTech's Avatar
TX
09-28-08, 06:06 PM   #9
Posted By: WildWillMorris i don't know, how do i do it?
Take the carburetor back off the engine, remove the float bowl and flip the carburetor over. If the float is pretty much level or slightly lower on the side opposite the inlet needle then it should be alright. If you need to adjust it, simply bend the tang on the float just above the inlet needle to obtain proper adjustment.
I also second cheese, check for spark when it dies as this could be the problem as well.
09-29-08, 05:40 AM   #10
Posted By: cheese Out of curiosity, when the mower dies, have you checked for spark during those 30 minutes that it won't start? Could be a failing coil if not a carb problem.
i have pulled the spartk plug and it was pretty black but not bad put a new one in and S.O.S.
09-29-08, 05:44 AM   #11
well, i have ordered a carb kit, new air filter, new breather, and new hose that goes from the carb to side of block. now if this don't help i'm going for new wireing and armature. what do you think now?????// and thanks so much for all the advise and help to all of yall. GI2
30yearTech's Avatar
TX
09-29-08, 07:04 AM   #12
Posted By: WildWillMorris well, i have ordered a carb kit, new air filter, new breather, and new hose that goes from the carb to side of block. now if this don't help i'm going for new wireing and armature. what do you think now?????// and thanks so much for all the advise and help to all of yall. GI2
While you have the breather off, check the clearances on your valves, particularly the intake. Make sure they are within specs, an intake valve with little or no clearance can cause the engine to run rich.
cheese's Avatar
GA
09-29-08, 09:34 PM   #13
Did you check for spark?
It does sound like you have carb issues and/or valve issues, but if you determine spark, it will eliminate certain causes of your problem.
God bless!
