Poulan Weed Eater-no fire
Old 09-25-08, 09:45 AM
R
I have a poulan weed eater 31cc. It has no fire. I hold screw driver in spark plug boot and finger in plug hole. It never has run correctly. I checked the on/off switch. It works right dis connected, but with both wires connected I get an ohm reading across meter on off and a slight lower reading in on position. Testing each to ground I get strong ohm reading in opposite and weak in other wire. I am grounding to the spark plug threads. It has been years since working on 2 cycles and any other. I can't even remember where fire comes from. Any help that anyone can give this old man, will be appreciated
Old 09-25-08, 09:48 AM
30yearTech's Avatar
The spark (fire) comes from the wire that the spark plug is connected to. If you are getting no spark with the kill switch disconnected, then the module is most likely bad and needs to be replaced.
Old 09-25-08, 02:50 PM
R
No Fire
Thanks 30 year tech. It sounds like it is shot. I expected as much. I appreciate your time. Have a good day.
Robertk
