Sthil BG55 blower - carb?
Old 09-26-08, 08:37 AM
O
This blower will run low but not with throttle. Gas is comming out the backside of carb. Too rich and I can't seem to solve it by the adjustement screws. Any suggestions would be most appreciated.
Thanks in advance,
Lance
Old 09-26-08, 09:26 AM
30yearTech's Avatar
If the carburetor is flooding it could be caused by a bad needle/seat, sticking fulcrum assembly, or bad stiff diaphragm. In any case the carburetor needs to be disassembled for inspection and most likely will need a repair kit installed as well a through cleaning.
Old 09-26-08, 09:36 AM
A
Check the muffler for blockage. Some mufflers have a screen, others have a stub (tube) with screen and BG 55 Series 4229 has a catalytic converter. Each of these can become clogged with carbon creating blockage restricting exhaust flow resulting in the symptoms you describe. Clean as required and only use Stihl 50:1 oil mix.
Other than the muffler you may have a carburetor issue.
I think your blower has a Zama C1Q carburetor. Here are some helpful links if it is carburetor related.
http://www.zamacarb.com/tipspage.html
http://www.zamacarb.com/tips.html
http://www.zamacarb.com/pdfs/TechGuide_2007.pdf
