snapper SR1433 rider
Old 10-04-08, 09:14 AM
i have a snapper SR1433 rear engine rider. runs great since i replaced the carb. i now have another problem,when going in straight line the mower seems to pull ok,then pops and jumps. if i turn either way left or right,the rear end pops and stops pulling then starts pulling again. i have replaced the clutch,clutch drive and washer. sounds like axle may be popping is the best noise i can describe to you. i have the mower jacked up and wheels off the ground and when i turn the right rear wheel,it turns for 180 degrees then catches like it ready to pull.
any suggestions or ideas for me?
thanks
Old 10-04-08, 09:29 PM
30yearTech's Avatar
May have an issue with the differential gears broken or binding. When you rotate one of the tires, does the other side rotate in the opposite direction??
Old 10-04-08, 09:46 PM
cheese's Avatar
Received 45 Votes on 40 Posts
I agree... something going bad in the rear end. It's a good chance it's the chain jumping.
