White Smoke
Old 10-04-08, 11:54 AM
White Smoke
Recently started my SEARS Briggs n Stratton LT 1000 riding lawn mower. I'M NOT mechanicly inclined. It started fine but after a minute of two engine seemed as if it were going too stall when a BIG cloud of white smoke appeared. After white smoke stopped lawn mower ran fine for a minute or two and same problem occured. Runs seems to almost stall white smoke appears. Can anyone help me with this?
Old 10-04-08, 12:16 PM
Speedwrench's Avatar
air cooled engine so that has to be oil smoke, check the engine oil level, if it is over full check for a fuel smell to the oil, if it has fuel smell you need to see if your carb needle and seat leaking fuel past, will also need a oil change if fuel smell to the oil. if not over full you need to pull the air filter off and check for a crankcase ventalition problem, last if these check out you probably have a cracked ring letting excesive amount of oil into the combustion chamber,
life begins when the kids leave home and the dog dies
Old 10-04-08, 09:38 PM
30yearTech's Avatar
My first thought would be to check the oil for fuel as described in previous post. Another possibility if your engine is an OHV style, is a blown or leaking head gasket.
Engine model and spec numbers would be very helpful for us to offer suggestions to you.
