Generator with no ouput voltage
Old 10-06-08, 08:53 AM
C
Hey there
I have a generator which has no voltage output.It hasn't been use much as it belongs to our Volunteer Ground search and rescue team. Luckly enough business as been slow!
I am thinking that the field has lost it's magnetism and needs to be flashed.
Hopfully you can Help with this
Here are the particulars on the generator
MAKE: Honda
Model: EM5000
Numers on the engine: GC05-2584047
AND
Honda GX340 337cubic meters
On the Electrical panel is the following
Sawafuji Elec. Co. Ltd
Model M50
No: C IN 053
Thaks for any help
Old 10-06-08, 02:44 PM
Hi- Have you checked the breakers- if okay-it's probably your rotor or stator - They are expensive to fix Good luck
Old 10-06-08, 06:43 PM
A
Here is a link that tells how to flash the field. This often works on generators of the type you have.
http://www.perr.com/tip16.html
Old 10-07-08, 03:50 AM
C
Thanks Air man I will give it a go. I also came acroos a wiring diagram for the generator so hope if I hafe to get at the feild windings for a chargwe I will know which wires to look for
I will let you know
Cheers
Chris
