17HP Briggs Intek 311777-0133
Old 10-06-08, 04:15 PM
R
Blows white smoke under load especially when going across a hill with the left on the down side. Smoke stops when load removed. I think it could be the head gasket. Mower has done 600+ hours,
Old 10-06-08, 06:22 PM
30yearTech's Avatar
Blown head gasket is a real possibility, also check and make sure oil level is right and not overfull.
Old 10-06-08, 06:41 PM
A
Your problem could be as simple as too much oil or a more serious problem such as cylinder wear or blown head gasket. There are two tests than should confirm the cause.
The first is a vacuum test using simple water manometer and the other is a leakdown test.
You can purchase a leakdown tester or make your own. Here are links that explain both.
http://www.perr.com/tip3.html
http://en.wikipedia.org/wiki/Leak-down_tester
http://vmaxoutlaw.com/tech/leakdown_tester.htm
http://www.compgoparts.com/Technical...akdownTest.asp
