wont shut off
wont shut off
i turn the key off and tractor keeps runing is this the switch or something else. its a murray. thanks
thanks for the info I guess it time for a new switch..
I put a new switch on and still wont shut off. I traced every wire from the seloniod to each switch and nothing off. Could it be another switch?
The solenoid is only for the starter operation and has nothing at all to do with the "kill circuit". Find the wire that plugs into the ignition module (coil) this wire is grounded to kill the engine, and usually the switch simply grounds this circuit to kill the engine.
