MTD only goes in Reverse
Old 10-11-08, 09:37 AM
K
MTD Lawn Tractor 42" red
Model #133K679G205 MFG code #1F143840053
sticker on back of trans or rear gearcase gives:
Model #618-0073
Serial # 462698
number on the bottom of trans:
719-0313
Problem:
When put in forward drive position and in any speed, when the clutch/brake is let out - it just gives a growling sound and does not move forward. Not sure if its gear noise.
When put in reverse in any speed and the clutch is let out - it moves backward like normal with no unusual sounds.
I ended up breaking down and splurging on a JD 318 before I had to make hay. Mowing in reverse with the MTD would have been a challenge, but was not up for it at the time. The MTD motor is great and thought I would take the trans or drive apart and get the old girl going again, but found you guys. Can you save me some hunting time?
Old 10-11-08, 05:15 PM
30yearTech's Avatar
Go to the MTD site
http://buymtdonline.arinet.com/scrip...15601_-1_19502
Enter your model number and click the search button. When your unit comes up, click on the transmission to get a blow up of your tranny. I think based on your description that items #15 & #17 are what is causing your problem.
It's not an overly complicated repair, but can take a few hours to complete.
Old 10-12-08, 07:51 AM
K
Thumbs up
Awesome! Looks like the right parts alright. You guys are worth your weight in gold. A couple hour job for you maybe - for me, probably about 8 hours. Thanks for the help. I like that little red tractor. Time to get the pigeon poop off and get her going again!
