Stihl SH85 stalls, or runs poorly when throttle applied.
Old 10-16-08, 06:34 PM
I have a Stihl SH75 blower, has been pretty reliable up until about 3 weeks ago. I went to start it, it ran great for 2 or 3 minutes, then began running very rough, and stalled out, I could start it again rather easily, but would die out again rather quickly when the throttle was applied. I have changed fuel pickup, changed the air filter, sprayed inside the carburetor with gumout, adjust the carburetor(LD screw), blew out the gas tank vent, still no luck. It seems to start fine, but after the first 2-3 minutes it dies out, the only way I can get it to stay running is to have it nearly at full choke, but even then it still runs poorly, I can see the gas making it to the carburetor, but am not sure how much it should normally be getting. Any help would be greatly appreciated.
Thanks
Scott Gregg
Old 10-16-08, 08:47 PM
cheese's Avatar
Received 45 Votes on 40 Posts
I'd start by removing the spark arrestor screen and try running it. If it runs right, then clean the screen. If not, then you'll probably need to disassemble the carb and clean it.
Old 10-17-08, 06:13 PM
I really appreciate your help, it runs great without the spark arrestor, do I even need the spark arrestor?
Thanks
Scott Gregg
Old 10-17-08, 10:24 PM
cheese's Avatar
It doesn't need it to run, but think about those dry leaves and the possibility of a spark blowing into the pile and smoldering away undetected. I don't know that there is much chance of that happening and being a problem, but it it were me, I'd feel better with it on.
You can usually clean the screen with carb cleaner and a wire brush.
