Poulan pro lawn tractor won't start
Old 10-17-08, 01:13 PM
B
Hi I have a Poulan Pro pr1842stb lawn tractor that won't start.I had the battery checked and fully charged and I also changed the spark plug. It still won't start. When I turn the key it makes 1-2 very labored slow cranks.I tried 3-4 times and noticed the starter was warm.Didn't know if it should feel that way in just a few cranks. I appreciate any advice. The leaves are falling,I'll be in trouble really quick if I can't get it started to keep up on them.
Thanks Orbit
Old 10-17-08, 10:33 PM
cheese's Avatar
Received 45 Votes on 40 Posts
You need to adjust the valves. Set both to .005" with the piston 1/4" past TDC.
Old 10-19-08, 05:27 PM
B
Cheese,Thanx but I have no clue how to do this.I'm fairly handy and not afraid to give it a shot,but is there a book I can buy that will show me step by step instructions? Or are there other resources you suggest?
By the way thanks for the blessing,I'll take it!
Old 10-19-08, 07:54 PM
30yearTech's Avatar
There are several threads dedicated to this procedure. Take a look and at these and if you have any questions, just ask.
http://forum.doityourself.com/showth...ghlight=valves
It's not that hard and it is normal maintenance, so it's a good idea to know how to do this, as it's needed periodically.
Old 10-20-08, 06:32 AM
B
thanx tech, I'll look'em up.
Old 10-20-08, 10:20 AM
B
Hi, just trying to get all my ducks in a row before I start.Will I need a set of valve gaskets?Also I noticed I have a little oil in the carb before it gets to the valve-choke.OK or not?
Thanx.Orbit
Old 10-20-08, 11:14 PM
cheese's Avatar
Is the oil level overfull?
When adjusting the valves, you may need to replace the valve cover gasket. Often times it comes off in one piece and if it looks good, you could re-use it at your own discretion.
